Thanks for posting. Good to see more verification falling in line with the others. Compared to your street tune, how did it change? I remember talking about this in another thread, but don't remember the timing curve. I'll add the curve to the op when I'm at a computer. |
Here are all 6 pulls from my last dyno session running an ~E20 Blend with about ~15% of my total fueling from Meth: http://i77.photobucket.com/albums/j6...ps088540e2.jpg Here is my breakdown of the benefit I obtained from the extra timing: http://i77.photobucket.com/albums/j6...psaa806230.jpg Basically, I normalized the power gain based upon hp per g/s to try to remove the impact of changes in MAF flow per pull, which can influence the end result. Per this analysis, I continued to gain power per g/s of MAF flow all the way up to my final timing (never found MBT)…It would appear that the diff between pulls 2-3 were somewhat anomalous in the 6000-6500 RPM range... |
subbed |
So I've read through this thread and the only person I saw that posted a 2.5gal mix timing curve was @Lex. His peak timing numbers are about in line with what I am running, but I was wondering where could I improve? Can I add more up top? I'm going to smooth the mid-range a bit to get my torque curve looking better. Here is my timing as it sits now. My number one goal is not to blow my motor so nothing too aggressive but a bit more power up top would be nice. Thanks for any help http://imageshack.us/a/img593/1530/49566647.jpg |
Let knock be your guide. Pretty sure you can't hit MBT on a 2.5 mix so find knock in each rpm column along your load curve and then back off a bit. Advancing timing in .5* increments is a safe way to do it. A knock decay rate of 150 will ensure that knock is localized to the area it's happening and doesn't perpetuate itself though out the run. |
I guess what I'm asking is I've seen other mixes as low as 3 gals with timing around 16-17 in the upper regions. As e85 tuners, would you say I have any room to hit 15 or 16 degrees? Or should I just stay put where I am until I can dyno verify? Thanks again |
Edit: only on the top end. That mid range looks like a good bit of timing already. |
I'll share my timing numbers. I'm running 31% though. From 4500... 12.50 16.00 18.00 20.00 21.00 19.00 Listen to @phate; He's good peeps! Sent while eating rice |
Ill bump her up a little bit and bring it down a cunt hair in the middle regions. Phate and Silva are the reason I run e85 lol |
One thing of note is that one of the guys I tuned (GT3076 at ~26 PSI) didn't gain any power at 6500RPM beyond 14° (dyno verified) so I would certainly urge caution when taking timing up too far without some detailed feedback on MBT. I keep gaining power up to at least 20.5° at 6500RPMs (haven't clearly found MBT yet)... |
Duly noted. I didn't see BT in his sig and his present timing looked like 93 timing so I figured he had a ways to go up top with timing. I was knock limited to 18* at 6k on a three gal mix. I don't want to see anyone vent their block so I'll refrain from posting in these types of threads where destruction may be lurking just around the corner. |
A denser charge requires less timing to reach MBT. The flame front will move faster. Typically you can't run as much timing on a smaller turbo as you can with a large one though because the smaller turbo will generate higher BATs, but due to the magic of E85 BATs don't matter so much. Zigatapatalka |
oh how I love the magic of e85 :slomo: |
The point is that every car is different and that assuming otherwise can be a very expensive mistake... |
The moral of the story is DON'T PUSH TIMING ON E85 WITHOUT A PROPER DYNO TUNE. Don't assume that your engine can use the same timing as others posted in this thread. Tapadatass |
Another thing to consider is the potential variance in each motors mechanical timing as well as the mounting of the Crank sensor. 1-2* variance is certainly possible and I have tuned a guy who's sensor was improperly aligned making his actual advance higher than commanded/logged. This lead to KR with very minimal timing and some head scratching for a few map revs until I had him re-align his crank to sensor setup. Tappin |
I had a speed 6 on the dyno recently and we didn't gain hardly any power above 14* at 6k. It's very important to keep run conditions and road the same if street tuning an aggressive timing curve, and I would still stay a little conservative. Sent from your couch |
Edit: Another note that is an important detail on this tune, is that he had a warranty engine replacement a few months ago, and it's likely the crank sensor is slightly off. |
https://sphotos-a.xx.fbcdn.net/hphot...83348607_o.jpg |
Occ. Weight 400lbs?????????????????? |
I totally missed that part. LMFAO!!!!!!!! :buttkick: |
i never got around to getting a different setup I just pulled it straight out of my truck thing is no joke ha http://imageshack.us/a/img809/2661/dsc00061e.jpg |
1 Attachment(s) so being as this is mostly about timing is anyone against discussing timing on meth since i dont have access to e85 up here in anchorage alaska...i will be jumping on a dyno very soon. using VD as my help i was actually able to hit Phates timing and still showed power being made. my timing is exactly as Phates is in OP up top. im running 90oct (the highest avail in alaska) along with 50/50 meth. i run a 1gal/hr nozzle pre turbo and 6gal/hr pre throttle body. vd numbers showed 325hp/410 iirc. im going to drop timing back down since yall fuckers making me nervous and go up all over again on the dyno. since im at work ill post this log just to tide yall over until i can post a vd if this is not ok to post here feel free to delete. |
I completely understand as well that's why I'm gonna drop it down some until u get back on a dyno. I don't get how I don't knock though. Motor is built and I'm sure ambient temps along with being at sea level has an effect on this. We just recently got a decent dyno in anchorage though and guy said I can make as many pulls for 100$ so I'm gonna take that deal and see what I come up with. Vd pisses me off these days. Shooting this ISH from my iPhone using forCUMrunner Thanks for chiming in as well lex Shooting this ISH from my iPhone using forCUMrunner |
Backed off about 4* through whole range and dropped boost as well. Gonna get on the dyno this weekend. How are you guys finding your power points? Are you adding a degree on top of baseline run to find benefits and then adjusting accordingly? Just want to have some tips and tricks to use when I go this weekend. Thanks guys Shooting this ISH from my iPhone using forCUMrunner |
You can add timing until power plateaus (sans knock). That last point where you pick up power is MBT. |
I actually run a blow thru maf and pre turbo meth. But will remove it tonight because I seen the fluctuating maf as well. Even before pre turbo meth I can seem to get the damn afr's to flatline. Figured it was because I was boost based. Would you recommend going maf based instead? Come on at around 3.4-3.5 volts and go max around 4.3-4.4? Shooting this ISH from my iPhone using forCUMrunner |
@ superdave2335 ; @superdave2335; Take it easy on those forged internals man. You are running some big timing down low. |
Thanks @rfinkle2; I turned the timing down. Wayyyy down. Gonna hit the dyno next weekend and do it correctly and accurately. Thanks for the heads up guys. Shooting this ISH from my iPhone using forCUMrunner Quote:
Try spraying post MAF Sent from my Galaxy Nexus using Tapatalk 2 |
How is that blow thru MAF working out? I've read the sensor doesn't respond consistently to that setup. |
It can be a little tricky the maf can seem to act finicky but as long as you take your time on maf cal it works just fine. And vta is always fun. I got a jbr wp intake with out recirc so that's another reason I opted to do it. Shooting this ISH from my iPhone using forCUMrunner |
Wow. I've also heard something like people only using the MAP with no MAF or something like that. Any idea what I am talking about? |
Its called Speed Density and we dont yet have the ECU logic to run it. Tappin |
Speed Density is a little advanced :) Factory speed density vs factory mass air....speed desnsity makes more power generally....start modding and the car goes to shit without a custom tune.....I converted cars from speed density to mass air simply for the ease of tuning and forgiveness of the mass air system. Speed density + mods is a game for the big power guys!!! |
That's what it was! Now what vehicles were those? Subies? |
Speed density from what I have seen here in Alaska is difficult when the weather changes and it goes from 80* outside to 0* lol. Shooting this ISH from my iPhone using forCUMrunner |
Topic for another thread but yes as VE changes so to must the tune if it expands beyond the table limits. MAF is much easier and more forgiving to hardware changes. SD is Robbing Peter to pay Paul IMO. Tappin |
Old fox body mustangs....87 and 88 had speed density from the factory...except the California models...they got mass air in 88 I believe. Anyway, back on topic :) |
Why? Speed density response is faster than MAF especially if the MAF sensor is so far upstream from the throttle plate. All the speed density does is it translates pressure into airflow for the engine. You can run a simple table translator such as this: MAP-ECU3 - Performance Motor Research : Performance Motor Research Plug it into your MAF harness instead of the MAF and make sure you map the VE table correctly. |
By Advanced, I meant to tune...not the technology. The typical armchair tuner would have quite a bit to learn tuning a modified speed denisity setup. Quote:
Don't you have to retune for changes in altitude on SD? |
You have to retune for everything with SD. Stock for stock a speed density car tends to make more power than a Maf Car. This is seen by numerous dynos with the 88 Mustang GT...this is my reference and experience with speed density. Anyway, as soon as you started modding the speed density system, car would react negatively. In order to reel it back in you had to piggyback the ECU and custom tune it. On the other end, the mustang with a MAF was much more forgiving. Heads/cams/intakes/headers/exhaust/superchargers...and the only thing that was needed to change were fuel pumps, fuel injectors, and maf housing...the maf housing was needed to be changed not for size but to complement the injectors.....these kinds of mods were not possible without extensive piggyback ecu tuning on a speed density setup. |
Are there any dyno proven values for in tank methanol? I'm running 1 gallon and was able to get away with 16* at 6k rpm holding 18.5 psi on k04. I tuned for what was in the tank and used WMI for more safety and consistency. Weird thing though, I recently turned off the WMI to verify my tune doesn't knock and I started seeing knock values at 5K. Idk why it would suddenly start doing that when it didn't when I was tuning for it. Also I've always been putting a full gallon in every fill up at empty, so there would always be residual meth in tank so I was usually just slightly over 1 gallon. |
Thanks @SofaKingAwesome! |
| All times are GMT -7. The time now is 12:13 PM. |
